Results 1 to 20 of 20
  1. #1
    Default 5.0 NO Electrical power except trim/tilt
    I have a 2006 Stingray 220 DR with a 5.0 Mercruiser. I have No electrical power Except trim tilt, EVERTHING is dead, Lights, blower, radio, ect. The battery is new and I have also ran a new ground wire to the engine block. There has to be something I'm missing, all the circuit breaks under dash are not tripped. Please help, I need some new ideas . Thanks, Bobby
  2. #2
    Default Re: 5.0 NO Electrical power except trim/tilt
    Quote Originally Posted by kimcrwbr1 View Post
    There is a inline fuse in the power wire at the battery?
    Yes sir, I've checked the fuse it's good. Thanks for the suggestion. It's has to be something simple. Just
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,837
    There is a fuse block on the starter.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    http://www.marineengine.com/newparts...s&replacement=
    How about the circuit breaker on the engine push the button in?
    Yes I tried pushing it in, and it felt like it was'nt tripped. But has some corrosion on it. I might replace..
  5. #5
    I will check the starter this weekend after Thanksgiving. But that doesn't explain why everything is dead. But I will still investigate.
  6. #6
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    The typical way mercury marine I/O's are wired,
    Trim motor is wired directly to the battery so it will work all the time.
    EVERYTHING else is powered thru the wiring harness. The harness gets it power off the starter terminal and goes thru the wiring harness to the dash. This power wire is typically a 10 guage RED.
    When it gets to the dash it may go directly to the ignition key or thru a fuse/breaker or maybe to a terminal strip where it may be distributed.
    If that power is interupted (blown fuse/open breaker, lost connection etc etc.) that is why NO POWER
  7. #7
    Quote Originally Posted by kghost View Post
    I've seen the red 10 guage wire going to the Starter, I need to check/clean the connection. And then look and follow it to the Dash/breaker/terminal strip. I've checked for thrown breaker and blown fuses, but found nothing. This weekend I'll check for corroded connections on everything.
  8. #8
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    If you have a test light 12 VDC type that would make checking for voltage easier.
    That way connect the clip to ground and touch what should be +12vdc and the light will light up.
    Makes trouble shooting quicker.........
  9. #9
    Thanks Kghost! I do have a test light, think bulb is blown. Will replace ASAP.
    I did notice last time I cranked the motor it turned over real slow. Could the starter be bad? Or thats where the loose/bad/corroded connection is?
  10. #10
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    Your guess is as good as anyone else's............cant see it from heya!!
  11. #11
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,837
    #8 on the parts list. 2006 will have this.
    https://www.mercruiserparts.com/Show...=Starter+Motor
    Chris
    Jersey Shore.
  12. #12
    Quote Originally Posted by Docksidemarineservices View Post
    WOW! Didnt know there was a fuse on the starter!! Thanks, I will check with test light. You Guys are the Awesome! I've checked my 5 day forecast and Saturday looks like no chance of ran. I will be working on da Stingray. Thanks again. I will keep you guys updated on my findings..
  13. #13
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    That is a 100 amp thermal type fuse. I believe it is 100 amp.
    Years back (late 80's early 90's) there was a service bulliten about paint creep. As virtually every inch is painted to protect from corrosion and the paint on that area could/would creep into the connection.
    It is NOT typical for this "fuse" to blow..........so dont be surprised if it is OK.
  14. #14
    These guys know their crap! Kghost sent me step by step directions, he keeps saying turn it counter clockwise. I was, but I had my out drive upside down on a drive stand I made , so what I thought was counter clockwise really wasn't whe outdrive was upright! They know the little things that us DIY's can easily miss!
  15. #15
    Update: This weekend I use a test light and found Power to the starter( heavy gauge red wire) and no power on the other side of the thermal fuse. It's has heavy corrosion on it, So today I ordered a new one. I will keep you guys up to date on my findings. Thanks again, I will be in touch!
  16. #16
    Join Date
    Jul 2008
    Location
    Northboro, Ma, USA
    Posts
    4,796
    What you could have done was remove the fuse and hook the wires directly to the threaded post of the starter to confirm that the fuse was the issue..
    sounds like it may have corroded so it may be the problem.........The fuse did not blow but corrosion got the best of it????
  17. #17
    Kghost, Thats a good idea! Wish I thought of that this weekend... Live and learn. lol
  18. #18
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,169
    a 10 gauge jumper wire (with decent alligator clips) could have done a similar function...
  19. #19
    Well the boat is RUNNING, the fuse bolted to the starter was the problem. It was a $25 fix, THANK You All for the help!!!! You Guys are AWESOME!!!!Thank you, Thank you, Thank you. Happy boating...
  20. #20
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,837
    Quote Originally Posted by Bobbyh68 View Post
    You are welcome.
    Chris
    Jersey Shore.
Similar Threads
  1. Bf 130 power trim-tilt
    By hdean in forum Honda Outboard Forum
    Last Post: 05-29-2012, 07:53 AM
  2. DP-C1 power trim electrical problem
    By tarheeltom in forum Volvo Penta Gas Engine Forum
    Last Post: 05-21-2012, 03:33 PM
  3. Power Trim Electrical Issue 2002 50 hp
    By mark45053 in forum Mercury Mariner Outboard Forum
    Last Post: 04-12-2010, 12:50 PM
  4. 1991 43L Mercruiser No electrical power except trim
    By jimbo66 in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2008, 08:14 PM
  5. Power Tilt and Trim for 60 HP
    By tnance in forum Yamaha Outboard Archive
    Last Post: 12-20-2006, 07:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
