Here is the problem,
its a 1996 yamaha 30deo hp 3 cylinder outboard engine,
When running down the river sounds like its missing and then it got that bad it was at full throttle and it couldn't get up on a plane,
I checked the spark and seems to be ok and when the engine was running i pulled off the top spark plug and it died and then tried the same thing with the second cylinder and it done nothing at all kept running like it was,
So i cleaned out the carbys and changed fuel hose and got new fuel and put in new spark plugs and still has the same problem,
I think it might be the reeds?
It ended up being 2 out of the 3 coils were bad and it was running on 1 pot most of the time,hi
i have the same problem.
can you help me ?
They would all show spark but they were not firing properly,
So check them all first before anything else
Very easy to check, here is a quick guide,
https://youtu.be/_kf1wfX5XAM
