Click for Ford Lehman manuals!
Results 1 to 2 of 2
    Default Ford 2712E Erratic Oil Pressure Problem (80hp)
    For the first hour the oil pressure is steady at 40 psi at 1600 revs. Then for the next half hour the needle flickers between 35 and 45 psi. After that, or if I increase the revs very slightly the pressure gauge tops out at 80 psi. There is no noticeable difference in engine performance or noise. Any ideas?
    Default Re: Ford 2712E Erratic Oil Pressure Problem (80hp)
    Could be an indicator issue. Is it an electric or mechanical gauge? If electrical, could be a bad sender or gauge, if mechanical, substitute another known good gauge.
    Quote Originally Posted by Neptune2 View Post
  1. FORD LEHMAN 80HP WORM DRIVE
    By jenny_green in forum Ford Lehman
    Last Post: 05-05-2011, 07:15 PM
  2. Fuel Pressure Problem 1994 PCM 5.8 Ford
    By xbcsutter in forum Pleasurecraft Marine PCM Forum
    Last Post: 08-29-2010, 08:54 PM
  3. Ford Lehman 80hp 254cu in
    By tbhudson in forum Ford Lehman
    Last Post: 03-10-2008, 05:44 PM
  4. Ford 2712E Engine spares
    By s_naragund in forum Ford Lehman
    Last Post: 02-24-2008, 11:10 AM
  5. Ford 2712E weight amp engine mounts
    By geoffgentil in forum Ford Lehman
    Last Post: 01-24-2008, 11:09 AM
