Jmcdan5655
After fishing and running about 50 miles within 4 miles of home my starboard engine changed pitch slightly followed by a decrease in RPM from 5000 to 4300 and fuel mileage went from 2.2 mpg to 1.2... Worked throttle up and down no change then seemed to get a little better. Port engine would turn 5400 normally 5600 WOT starboard only 4900 rpm WOT. Pulled both engines down to same rpm and economy came back to almost normal. Figure the port was a little low due to starboard not putting out its share. Came off plane boat is heavy (Everglades 240cc) so was thinking it wouldn't want to come back up on plane but did fairly normal but was very obvious lower power on the starboard engine. Engine is a 2006 with 260 hours no alarms ever.. Looking for ideas where to start. Will pull plugs, as well as gear case oil (just changed to make sure no leaks and undue friction) and go from there (the normal fuel filters will be checked as well) any other ideas? Engine had a definite change in pitch but maybe just from the change in RPM felt like we had snagged something that was putting drag on the bottom of the boat but checked just to be sure and it was only one engine so knew that wasn't it. Any help where to start would be appreciated!
