Replacing engine drain fitting on Chris Craft KBL engine
jlash
On my 1955 KBL Chris Craft engine, the block drain is shot and needs to be replaced.
As you know it is buried and very hard to get at. Do I need to remove the the pump and distributor drive to get at it, or is there a trick someone has used to remove and replace this fitting? If I have to remove the pump and distributor drive what bolts do I remove and anything I have to look out for so I don't screw something up?
