Hi all, I have a Honda 90HP 2005 which I bought second hand and have no history to it. It was lying for 2 years. I sent the carbs away to a dealer to get serviced, when I pulled the leads off number 1 - no change in tone, then it fixed itself and was running fine. Went to it today and pulled the leads of 3 & 4 no change in tone ,Plugs were wet so was getting fuel. checked compression 180 180 180 190 in cylinders. There is sparks to all the leads. Do I need to balance the carbs would this help? , Or has anyone got any other suggestions as new to this. Also Tried to take lower unit off managed to get 5 bolts off but seems to be stuck? Cheers for your help anyone
