Hello all,
Recently purchased a boat with a 1988 25hp Mercury, serial 0B254011.
Runs great for a few minutes, then bogs down to a VERY reduced power level. Rough idle, only reaches 5-7mph at WOT. Cleaned plugs on the water, didnt help. Randomly ran good for 2-3 more minutes, and then repeated the problem. Headed back to the dock, it would "blip" more power for a second or so, then continue bogging.
Brand new gas tank, lines, and fuel, bottle of seafoam in fuel. Ran great when it wasn't misfiring.
No DVA meter, but I checked ohms from CDI's troubleshooting guide, stator ohms are low as follows:
Black/Yellow - 3060 ohms, spec 3250-3650
Black/White - 136 ohms, spec 150-250
Trigger ohms good. I dont have specs for the coils, but they are identical to each other, ~1ohm + to -, ~950 ohms plug lead to -.
I'm looking for any opinions, if I should order just a stator, or switch box as well. Anything else to check?
Thanks in advance, been awhile since i was on here.
Terry
Terry
