I inadvertently picked up a container of Quicksilver Premium Plus from Walmart recently (its a bit of a trip to get it), and didn't realize what I'd gotten until I returned home. I'd previously been running the Quicksilver Premium. I ran the old oil (Quicksiver Premium) down to near the bottom of the reservoir, then filled up with the Premium Plus. Engine is running fine (though I do think its bogging a tiny bit more on holeshot), but I've noticed that the exhaust ring, spindle and nut of the prop are much oilier than they were previously. Previously, they had a light, dry, carbon'ish coating on them, but were largely dry. Now, they are definitely coated in an oily film - not dripping off or such, but enough to leave a sticky black mark on your hand if you touch anywhere in there. I presume that this is due to the difference in the oils used in the Premium vs Premium Plus, but want to be sure that I'm not causing problems (fouling, clogging, etc) for the engine, and I do worry a little bit that I may be leaving more oil behind in the water, when running the engine. (I'm a boat noob, BTW, so please keep that in mind with this thread
So, does this sound normal? Is it anything I should be concerned about? Should I stay with the Premium Plus (now? going forward?) or revert back to the Premium?
BTW, this is on a 2001 Mercury 90 HP 2 stroke (oil injection), which runs very well and has a consistent 115 psi compression reading on all 3 cylinders, FWIW.
Thanks for any assistance!
