livetofish64
Recently my son purchased a vintage 16' Orlando Clipper with a Johnson 40 hp (Model RKL-28). The compression seemed ok (105 psi & 95 psi). With this compression should I expect the boat to run slow? It seems to be responsive but it just can't seem to get over 15 miles per hour. I de-carbed the engine and cleaned the carb. I replaced the water pump and thermostat as well as replaced the throttle cable. The engine idles well and is responsive at full throttle but just seems like it wants to go faster but can't. I removed the port side exhaust panel and noticed the heat exchanger was rusted out near the bottom piston. Could this cause it to over heat and affect the top-end performance? I hope someone has some advice. Thanks
