Results 1 to 5 of 5
  1. #1
    Default Ted Williams 7.5 model 217.59490
    New to outboards. Trying to get some help with removing main shaft to replace seal under impeller. Any info would be greatly appreciated! Thank you
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: Ted Williams 7.5 model 217.59490
    Part nimber 48 is your hold up, the ring reatiner...or circle/C clip,( she hold the bearing in and the drive shaft will not come out or the will the gear set until this removed, you need a smaller set of clip pliers for these as a rule, once you remove that its all cake my friend, and just a note, when you reinstall it, the flat side of the clip goes down.
    http://www.searspartsdirect.com/part...hdMod=21759490
  3. #3
    That explains it! Thank you
  4. #4
    Join Date
    Aug 2010
    Location
    Posts
    138
    handy feller an't I lol really unless you knows its there its hard to see it. just remember flat side down on installation, it will go in upside down but has the nasty habit of popping out under load and will frag the lower unit
    and your welcome
  5. #5
    After popping lower portion of impeller housing free... (Which i originally thought was part of lower unit) . I was able to remove the white plastic piece that contains the seal and not even mess with the clip and bearings!
Similar Threads
  1. Ted williams 45hp model #21759464 year parts
    By itsdep in forum Ted Williams Outboards
    Last Post: 12-01-2012, 03:50 PM
  2. 1974 Ted Williams model #217.59680
    By Ed Ruszkowski in forum Eska Outboards
    Last Post: 07-03-2011, 10:30 AM
  3. Ted Williams 7.5hp Model 574.60121
    By Sally15000 in forum Ted Williams Outboards
    Last Post: 07-07-2010, 06:28 PM
  4. SearsTed Williams 45 hp Outboard model 21759463
    By timhrmn in forum Ted Williams Outboards
    Last Post: 04-09-2009, 10:37 PM
  5. New 1974 Sears 55 Ted Williams signature model
    By roy in forum Outboard motors archive 2000-2004
    Last Post: 02-04-2003, 06:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
