Re: Volvo Penta AQ131A Cooling System
i like your line of thinking on this solution. the cooling system, ( at least on my aq120) is only 4 psi at the radiator cap.with those threaded in, in my opinion, the o rings are way more likely to fail before your setup would. when mine gets degrades to that point.....that is exactly what i will be doing.
*** In comparing the virtues of various calibers, using hollow point ammo: it is absolutely undeniable that, while a 9 mm or .40 S&W may or may not expand, a .45 will never shrink. ***
