Click for Perkins manuals!
Results 1 to 2 of 2
    Default PERKINS 4.107 starter ring gear
    I'm mending a whaleboat (lifeboat) the Navy. Year 1967 (28MWN707 record belonged to the USS BRADLEY)).I could not identify the engine serial number it. For the research I've done seems to be a PERKINS 4.107 / Westerbeke '. I need parts for it. The starter ring gear has 104 teeth and inner diameter about 412mm.
    Any good sailor can help me identify the engine. Follow the attached photo. confirm whether there is a 104 tooth starter ring for perkins 4107? Thank you.Click image for larger version.
Name:	motor westerbake 4107.jpg
ID:	7804Click image for larger version.
    Default Re: PERKINS 4.107 starter ring gear
    looks like my 107
  1. Perkins 4-107 Starter
    By capron in forum Perkins
    Last Post: 08-31-2013, 03:28 AM
  2. 1987 PCM Starter Ring Gear
    By Terry Benton in forum Pleasurecraft Marine PCM Forum
    Last Post: 04-11-2012, 07:06 PM
  3. starter on my Perkins 4-108
    By gardensaga in forum Perkins
    Last Post: 10-30-2010, 12:02 AM
  4. Starter gear throw depth into ring gear
    By mechman in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 03-06-2008, 02:45 PM
  5. Starter will not engage ring gear please help
    By suckerswim in forum Mercruiser Sterndrive Archive
    Last Post: 05-21-2007, 03:28 PM
