" Ok, here is some more infoma
" Ok, here is some more infomation . . .
I ran the motor for a minute or so, trying to determine the general area that the knocking noise is coming from.
No knock at idle. Starts knocking after I raise the high idle lever and the RPM's come up a little.
The outer breather cover is off and I notice exhaust(?) smoke coming out, along with light sprays of fluid(gas?) spitting out of the carb throats.
The knocking noise sounds like it is coming from or near the carb area, upper half. Could be just because it's easier to hear from there, as the carb throats are there. Sounded the same from in front (while starting) and from each side.
The overheat buzzer then sounded and I shut her down immediately. I couldn't touch the motor near the plugs for even one second.
Then I noticed the water. . . .
The lower unit is in a garbage can full of water. The water is now a milky color, but is clearing after a few minutes. Feels cool to the touch, but is slightly oily.
Also, the water coming from the tale-tell holes (slots) weren't a steady stream, but constant coughs of water. I have recently replaced the impellar and housing.
Where to start now???? Am I doomed to a complete overhaul?
Thanks, all.
Jason "
