Anyone offer some insight into how the check valves work on the manifold of older outboard Johnson and Evinrude Outboards. Many Johnson/Evinrude motors use these with the fuel recirculating system. OK, I get that. My specific motor is a 1984 Johnson 90hp V4 but these nipples(check valves) are used on many outboard models. The factory service manual describes how to check them, inspect that they function correctly, and they should only flow one way...I pulled the ones off my engine and there is no one way valve system, just a filter screen. The replacement check valves from the marine engine site look exactly the same so what is the deal. Have mine simply been modified and a replacement actually has a one way valve?? Anyone help...Thanks
