jsh_omc4.3
I have an 89 omc 4.3L cobra with power steering. Last run on the water, the power steering reservoir slightly overflowed and the fluid was milky / mocha in color. When I run the motor with muffs on my driveway, I notice a slight oil sheen on the water running on the concrete from the lower unit.
Am I correct to assume the oil cooler is toast and needs to be replaced or should something else be checked? The motor does have low hours for being 24+ years old but the oil cooler is original equipment.
Thanks for any advice, James
