I just bought a Sea Sprite with a Mercruiser 120. The boat is a winter project that has potential with a great trailer, hull, solid floor, no seats but he gauges all seem to work and light up so far, trim works, and the motor appears clean on the outside for what it's worth. So it was said to run great a couple years ago. It's been turning over good and seems to get fuel but no spark. I was in the process of checking the coil and read here somewhere that the Tach could be bad and causing a ground and in turn causing no spark. So while I was checking things out I removed the grey wire from the coil as I thought thats what I read how to check on the bad Tach. Tried to start it and nothing, I mean absolutely nothing, no cranking....dead. So I re-attached the grey wire, tried starting and heard a small bump or tick almost like the motor bumped over ever so slightly then stopped. Then dead again. Wont crank. Battery is great. So now I'm worse off than no spark. Anyone have an idea what I may have done or is this just a freak problem that would have happened in any case. Very strange. Maybe a shift cable problem? Like it thinks it's in gear? Hard to believe the grey wire had anything to do with this?
