Results 1 to 9 of 9
  1. #1
    Default 1971 Ted Williams 7hp 217-59440
    Hi everyone. I just acquired this outboard and doesn't seem to be in that bad of shape. I don't have a manual so if someone has one in PDF could you please share?!
    Also need to find some piston rings....ideas on where, sizes etc...?
    The cover says to use leaded gas.....anyone know if there is issues with using unleaded??? Or do you have to added lead additive in your gas mix???
    thanks for your help will post more questions as they come up.
    cheers
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: 1971 Ted Williams 7hp 217-59440
    I would like to see that "use leaded gas emblem", that would be interesting,
    But I can tell you for a fact unleaded gas is the ticket for a 2 stroke marine application, in the old days it was called "white marine gas" totally unleaded 87 octane.
    go to www.cerifiedpartscorp.com/vintage and call about a manual and rings, or there is "Gary" I can't seem to remeber his url ???
    The one bad thing about the 7hp AV 750 is the reed cage, the manual says it needs replaced with the carb kit, they were just that flimsy ...oh yeah
  3. #3
    I was able to find parts at www.discount-marine-parts.com I've been rebuilding a 68 9 horse and they have every part I needed. He gets the parts made for him. There number is 1-906-466-2180. They are out of bark river michigan and they ship nation wide. Give them the model and serial number and they'll have the parts
  4. #4
    Join Date
    Aug 2010
    Location
    Posts
    138
    Yeah thats our boy Gary, how did that you can't get it except from us shipping cost feel? ( not true ) I hope the old fat lady has changed her greedy ways,,, but I doubt it.
  5. #5
    I wasn't impressed with the $6 shipping but I did burn up the 1st water pump impeller I got from them, gave them a call and he replaced it at no charge so I can't complain
  6. #6
    Join Date
    Aug 2010
    Location
    Posts
    138
    4 years ago I needed a set of 7.5 rings, the woman up there quoted me 18$ !!! for the rings, OK Yeah I need them for a customer, I was a little un suspecting and expected something like $6 shipping... when I got the package UPS ground w/recipt, I had payed her 20$ just in shipping. 38$ for a set of 6 dolla rings?? I did a bunch of "tell me why??? I want some money back gal" then yelling but no pitty was found,
    That cluster set me on the search for the source and now I have the answers, however becuase of my sensitive position I do not push it or promote it...
    I do think I may have helped rock them into reality when I disputed and received the back charged for the shipping cost. Got to love my platinum Sears Mastercard people "priceless"
    Good luck, I hope you get it lines out,
  7. #7
    Need help finding a clutch assembly for a sears ted williams 7 hp. Help please.
  8. #8
    Did you ever find them I am needing same pars for mine
  9. #9
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    4,750
    If it is a air cooled engine you can use regular chainsaw oil mix. Back in the day they used regular 30W-HD for the mix the new two stroke oil has both the lead and the detergent two stroke engines require.
    It takes a nickle to go first class!
    If it aint broke dont fix it!!
Similar Threads
  1. Replies: 2
    Last Post: 08-26-2013, 10:58 PM
  2. ted williams 5.5
    By seekersmotor in forum Ted Williams Outboards
    Last Post: 05-12-2010, 03:20 AM
  3. Ted Williams 99
    By denpell in forum Ted Williams Outboards
    Last Post: 10-09-2009, 01:42 PM
  4. 55 ted williams
    By tom_finch in forum Ted Williams Outboards
    Last Post: 09-01-2009, 07:02 PM
  5. Ted williams 4 hp
    By botch in forum Ted Williams Outboards
    Last Post: 06-19-2009, 09:22 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
