Results 1 to 2 of 2
  1. #1
    Default '48 Ventnor 18 Gray Marine flat six fireball 150, dual Zenith updraft carbs
    Hi All,
    So I have an old Ventnor barn find I picked up last year. It appears to have not been in the water in 40 years judging by what I found and the condition of the belt, hoses, clamps, etc, all being very old technology.
    It's a 6 volt positive ground electrical system, with dual Zenith carbs, updraft intake manifolds.
    When I got it the floats were so far out of adjustment on the carbs that fuel couldn't enter the bowls. I rebuilt both carbs, set the floats, replaced the head gasket, the cylinder walls and valve-train are in great shape, very little wear.
    The valves are set to spec. I also rebuilt the starter, new brushes, bushings, cleaned, it has a 6 volt electrical fuel pump, with an integral filter which I cleaned and also replaced the inline fuel filter.
    I cleaned the air filters for both carbs, replaced the battery and cleaned all the terminals, wiring etc.
    I replaced the head gasket with David Vaness' copper gasket and torqued. New plugs, checked the points, cap, wires, rotor and had to weld new teeth on the flywheel with my TIG welder and filed them up to get the starter to engage.
    I've had it on the water a few times, and this last week I made final adjustments to the carb jets, idle and main, also the ignition timing. All in all it runs great, starts up and idles at first push of the button, but I cant get the engine to speed over 3000 rpm and it only goes about 25 mph, the Ventnor literature states that this model with the fireball six 150 should go 42 mph. I've also checked and adjusted the linkages for the carbs and I'm certainly getting full WOT on both. The prop is also in good shape. Does anyone know the maximum rpm for that engine and what am I missing to get more out of it?
    TIA
    Kevin
ID:	7666Click image for larger version.
ID:	7667Click image for larger version.
ID:	7668Click image for larger version.
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,172
    Default Re: '48 Ventnor 18 Gray Marine flat six fireball 150, dual Zenith updraft carbs
    Welcome to ME.com!
    As far as the specs go, you might try over at oldmarineengine.com...more interest in that vintage there.
    As far as limiting out at 3000 rpm, it sounds like you touched on everything but timing advance...lack of timing advance will limit the engine's power output as well as rpm...
Similar Threads
  1. Gray Marine Fireball V8 CF 185
    By willham in forum Gray Marine Gas Engine Forum
    Last Post: 08-27-2012, 07:01 AM
  2. Gray Fireball free to a good home
    By seabird in forum Gray Marine Gas Engine Forum
    Last Post: 11-16-2010, 11:51 AM
  3. Chrysler M8 amp M6 and gray marine 220 fireball any value
    By DJR in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 07-21-2006, 02:32 PM
  4. Gray Marine Flat Head SixWater in cylinders
    By Jonathon Herbert in forum Archive 2003-2007
    Last Post: 06-06-2006, 01:35 PM
  5. Tunning Zenith carbs
    By robert wood in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 03-06-2006, 09:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
