Re: Another water heater problem
The engine coolant supply (to the WH) must come from upstream of the engine thermostat.
This creates a mild coolant pressure caused by the circulating pump that is constantly charging the engine block with coolant.
The engine coolant return (from the WH) must feed into the engine circ pump suction side.
This allows for taking advantage of the pressure differential between the two sides.
No pressure differential..... and you'll have insufficient coolant flow to/from the WH.
Also, and perhaps a long shot..... your WH outlet (supply) must be taken from the port that leads into the upper portion of the WH tank.
Cold water enters the lower section only.
If these were reversed, it may cause your limited amount of warm/hot water.
Rick ... aka Ricardo..... AQ series Volvo Penta repair
Portland, Oregon
28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
"Intellectual growth should commence at birth and cease only at death." Albert Einstein
Please... no PMs! Post your questions on the forum.
