We were out for the weekend the other week and I suddenly saw 15+ volts on the gauge. Being Saturday night, I hoped to pick up a new voltage regulator (checked and saw excess voltage at the batteries) on the Monday. Heading up-river the next day, the boat just cut out dead. No spark. Had a spare ignition module (Thunderbolt) and swapped that out. No spark. Left the boat tied to a dock at a trailer park and picked up a new voltage regulator on Monday. I'd had the alternator re-built a couple of yrs. ago, after it quit charging, and had assumed (wrongly, the reg. cost almost as much as the re-wind) all new parts. Swapped the volt. reg. and no dice. Realized I had kept the stock coil after changing out the ignition parts last summer. Presto, spark, and 14 volts. I'd been seeing 14.5 for a bit, and hadn't worried. as that's what my bikes charge at. Anyhow, I have an old coil of unknown age in my boat again. I had the option of spending 50 bucks (Canada) on an aftermarket stock coil, or getting a hotter coil for a bit more. I've bought a lower resistance 45,000 volt "flame-thrower" coil. Here's my question. I was told it is compatible with the Thunderbolt ignition, but am curious if anyone has any experience with changing from stock parts. I'm not expecting miracles from a hotter coil, but it would be nice to get a bit better fuel burn at lower RPM. Haven't messed with the plug gaps. Plug wires are new, quality wires, but nothing fancy. Distributor and pickup is new, 4bbl carb is rebuilt and motor has 20 hours on it after a re-build. Any thoughts on using a hotter coil, and anyone had a coil failure like mine? A couple of hours tops at 15.5 volts enough to fry it?
