I know running a long shaft motor on a short transom will yield no performance. Having said that.
The motor can't get the 13' inflatable w 2 ppl (370lb) to plane. The average speed is about 5mph w a max of 7mph. I checked the compression and both cylinders are 90-100 psi. What the normal psi for this outboard?
I also noticed excessive white smoke from the exhaust at idle when I'm in the water. When I start it up at home w a hose I don't notice too much white smoke.
Theres a black hose coming out from the back of the motor. Water comes out of it. I'm guessing this is to let me know the water pump is working. I see water coming out of it. Do I just let this dangle behind the motor or should it go somewhere?
Besides that, the motor starts up every time.
The original owner told me it was a short shaft and I took his word for it.
Fuel was pouring out the carb but a rebuild kit took care of that.
I'm planning to sell this and get a short shaft but don't want to sell it if its not running right.
