Put the NEW impeller next to the old and see if they are the same height?They should be about the same size as the other.PICS?? 47-803630t is the part #From Mercury Be careful as they always seem to want to sell the Mercruiser impeller.It looks real close but it's taller and a bit bigger around. Not going down all the way it could be the key slipped and it's holding it up. Install the key, slide the imp all the way down. Then GREASE the whole thing. Slide the housing down to the pump.Then turn the driveshaft as you push the housing down over the impeller.
