With the ignition key on only, the fuel pump will not be receiving power.
In order to receive power one of two things needs to occur;
1.... Engine oil pressure must close the normally open oil pressure switch.
2.... The start-by-pass circuit must close the circuit during cranking.
where would i find the oil pressure switch
Usually Port side, down low and near the OEM oil filter location.With the ignition key on only, the fuel pump will not be receiving power.
where would i find the oil pressure switch?
This will be a N/O switch, so when you test it the circuit will be "open".
You could temporarily jump the two terminals, and see if the pump operates.
NOTE: it is a USCG regulation that this LOPS be active and NOT circumvented.
