Click for Honda Manuals, Parts and Model Guides!
Results 1 to 3 of 3
  1. #1
    Default 9.9 4-stroke Honda can't hold idle after 3-4 winters
    My 9.9 4-stroke Honda was revised some 3 years ago and worked beautifully since then.
    Now, just as every 3-4 years with most out-bords, it tends to stall when in idle (even if warm), which forces me to gear in at higher rpm.
    Obviously these little babies suffer from spending winters outside and being used a couple of times in summer, but I would appreciate your advice on what I could clean/adjust to avoid spending 200 bucks for nothing.
    Thanks in advance!
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    11,713
    Default Re: 9.9 4-stroke Honda can't hold idle after 3-4 winters
    This is classic of a carburetor that needs to be cleaned.-------Fuel sitting in the carburetor tends to plug up the tiny jets / passageways.------Fuel must always be run out when boat sits unused!!----Some folks on here have struggled with this and finally got the carburetor clean on the third try.---It is quite simple to do if you take your notes and work carefully.
  3. #3
    Superb!
    Thanks Raceone for this answer, it's very helpful.
    Apparently, there are some pretty good YouTube videos on that
    http://www.youtube.com/watch?v=inlzFz2KPf4
    http://www.youtube.com/watch?v=Y_xFQwtvtj8
Similar Threads
  1. pre 1997 honda 5hp 4 stroke will not idle
    By sre112 in forum Honda Outboard Forum
    Last Post: 09-22-2011, 08:24 PM
  2. 1989 110HP Johnson Will Not Hold Idle
    By mr_johnson in forum Johnson Evinrude Outboard Archive
    Last Post: 03-18-2008, 04:34 PM
  3. Mercury 1994 135HP V6 BlackMax Idle Surgewonbt hold low Idle
    By tracsand in forum Mercury Mariner Outboard Archive
    Last Post: 11-18-2007, 05:02 PM
  4. Wont hold idle
    By bray in forum Mercruiser Sterndrive Archive
    Last Post: 07-03-2006, 12:26 AM
  5. 350OMC No Power Wonbt hold idle at less than 1200 RPM
    By bdonald in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-26-2006, 01:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
