carrnflight
Bought a pontoon that has a Johnson 60 VRO on it. The VRO had been disconnected and my plan was to reconnect it. Plan was to get the engine revived on premix and then reconnect all the VRO stuff. I connected a portable 6gal tank with 50:1 premix and started pumping the bulb, I found fuel squirting out of the oil side of the VRO pump. With this I started looking for a VRO pump and found they are running in the $500 range. I refuse to spend that much on a pump that I consider to be high maintenance not to mention having to replace the oil line and tank and all the little hoses. So can someone give me a part # for a pulse pump that will work in place of the VRO pump, and I'll keep doing the premix thing. ( this is my first VRO, so premix is old hat to me)
