ronnierockcod
Was running my Ninety (BBBL1006849) in a water tank in neutral gear at about 2500 rpm. I had a solid water stream from the pee hole. After about eight to ten minutes flow began to decline to a dribble within a minute or two. After shutting down I figured the water pump needed repair or replacement. I found no mention of a water pump in my shop manual only "Water jacket cover/thermostat/thermoswitch." Nothing in the illustrations or mention of a pump. In advance I welcome any advice to repair an obvious water flow problem or where I should look in my shop manual. Thanks, Ron.
