I have never noticed before if this is a problem or not as the boat is typically stored on a lawn, but now that my boat has been in the driveway this summer I've noticed I've got gear oil leaking from the lower unit. I recently took the lower unit apart to replace the impeller, but it's been used for about 8 hours and now that it's been sitting in the drive for 2 weeks, I've noticed the gear oil leaking from a small hole on the LU, opposite the fill hole, on the starboard side. It's not much, maybe only 1/2 ounce or so but nonetheless concerning. Is this okay or did I screw up when putting it back together? I was very careful to replace and seat the o ring between the upper and lower.
