lowearthorbit
A friends 4.3L ignition has had points replaced with electronic module. Same coil and wiring. Does he need to keep the purple resistance wire to coil in place or can he achieve some extra performance by bypassing purple resistance wire to coil primary, (without burning out coil of course)? If the resistance must stay what aftermarket coil would be a good substitute to enable getting rid of the resistance wire/ballast.
If he were to replace the 10 yr old ignition module for the latest and greatest, what system would that be for best reliability and performance?
BTW fuel system is original Rochester 2bbl 380 cfm carb.
Thanks!
Thanks!
