Thanks for your attempt to help. The spring for key return (immediately after starting), went out in the old ignition. At the same time, there was zero response from turning the key. At this point, bilge pump and livewell pumps both still worked.A more in-depth explanation of what it is/isn't doing would help.
Thanks so much for your help. At the same time the ignition switch went out, the solenoid went out. After replacing solenoid, problem fixed.Check the fuses and recheck your work. If it worked before and not after the new switch you did something.
