I started this motor and it ran fine shortly then it sputtered, ran low and died, sounded like a fuel issue. Now the ignition lights when turned to start do not flash and I get a slight buzzing noise from the electronic relay below the alternator. This has a wire going to the negative on the starter solenoid, the green light on the ignition panel stays on though. When turned to the on position it does nothing. I am wondering if this needs to be replaced, or if the grounds need to be checked.
Thank you.
Thank you.
