I have a pair of 150's that idle rough the code they are showing is A/F sensor I checked the Ohms on sensor does not seem to be bad. I have run them hooked to a water hose and the water coming out of the pee hole stays cold could the problem be the thermostats not letting the motors get up to the right temp. Also while the motors were running I unhooked the A/F sensor and they ran a lot better.
