So I am still at the stage of using a pump to draw the oil through the dipstick opening. I am planning on adding a pump (Like X-change-r) to make this easier. I had a couple of questions based on my recent experience.
1 - for the pump I want to add, I will be attaching to the low bolt (sump bolt?) and I think I can do both drain and refill from that point, correct?
2 - the oil refill point on top of the engine (attached to the sponge air filter) seems very loose, is there something missing (a gasket or something?) it seems to be very loose, or is this normal?
Reb
Reb
