Apparently the fuel passages internal to the carb are restricted, or the filter is restricting flow. Did you soak all non-rubber carb parts for at least 4 hours at room temperature in carb dip, followed by a thorough blow-out using generic carb spray? If not, start there. By "rebuilt", do you mean that you installed a new needle, seat and float, along with gasketing? That was probably a good idea, but is not a substitute for a proper cleaning.
A pint of TCW-3 is enough for 6 gallons. You will foul the plug if you run that much oil. The correct ratio is 50:1 gas-oil.
The fuel cock (attached to the tank) has an integral filter, which can get clogged. See p3-8 and 3-15 of your Factory service manual for location of the fuel cock. If clogged/damaged, it's best to replace the fuel cock (comes with a new filter).
