MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Question 2008 60 hp EFI (not big foot) slight miss at idle then will not go to full throttle
    2008 Mer 60hp EFI has a slight miss at idle then will not go to full throttle, runs rough. This is my first experience with an outboard and want to get this right. I am guessing maybe a fuel pump issue or bad plugs. We have replaced fuel lines and cleaned plugs, will replace fuel filters when they come in. Have checked for tightness of the anchor bolts on the fuel pump.
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Re: 2008 60 hp EFI (not big foot) slight miss at idle then will not go to full throttle
    Sounds like either a lack of spark or fuel issue. Verify each spark plug can jump a 7/16" gap w/a loud snapping blue spark...use a spark test board available at most autoparts stores.
    ...cleaned plugs
    Try new plugs.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Nov 2011
    Location
    tennessee
    Posts
    2,854
    Could have a injector flooding or dirty...
  4. #4
    So here is what we have done thus far with no change in performance. Treated fuel, changed fuel lines, new lower fuel pump, changed both fuel filters and all new plugs. Really don't want to have to take to the shop for repairs. Hubby is pretty handy on motors but doesn't have exp. with the EFI motors so he is a bit reluctant to dive too deep into this thing. Is there anything else we might be able to do? We took it out Sunday, still slight miss, ran rough up to about 4000 rpm, smoothed out but then wouldn't go above the 4000rpm mark. Never dies and always starts right off.
    Quote Originally Posted by guyjg View Post
    Sounds like either a lack of spark or fuel issue. Verify each spark plug can jump a 7/16" gap w/a loud snapping blue spark...use a spark test board available at most autoparts stores. Try new plugs.
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Do you remember what the old plugs looked like before cleaning them...what color were they? Get a cheap spark tester at an autoparts store and test the spark at the end of each plug wire. Get one that the gap can be adjusted. Open the gap to 7/16" and see if there is a loud snapping blue spark at each wire end.
  6. #6
    They were sutty looking. Since my last post, I have learned that this motor is still under wÓrrnty. When the original owner purchased in 2009. MERCURY had a ptomotional earrenty program so it has a 5 yr warrenty, good until March. 2014. Now just got to pray ehatever is wrong will be covered.
  7. #7
    Red face Re: 2008 60 hp EFI (not big foot) slight miss at idle then will not go to full throttle
    Quote Originally Posted by mmrando View Post
    07/08/2013 UPDATE: Just wanted to thank everyone for their input. However, after discovering Wednesday that we still had warrenty left on the motor, thank GOD!, I took her into a Mercury dealer. Bad coil at number 5 cylinder and with the recall that had been previously issued by Mercury, even though my serial number was not tagged as being in that recall, Mercury gave the go-ahead to replace all the coils. Shop said she looks and runs like new again. Can't wait to get her back out on the lake.
Similar Threads
  1. 99 evinrude 4 stroke cuts off at idle an has 3/4 throttle miss
    By Porterhouse in forum Suzuki Outboard Forum
    Last Post: 04-03-2012, 10:11 AM
  2. 1985 60 hp Intermitent miss at full throttle
    By oneeyemike77 in forum Mercury Mariner Outboard Forum
    Last Post: 04-10-2011, 11:09 PM
  3. BF 150 miss at full throttle
    By jlblau in forum Honda Outboard Archive
    Last Post: 06-10-2008, 02:20 PM
  4. Rough idle and slight miss at higher revs
    By aquakenbush in forum Volvo Penta Gas Archive
    Last Post: 06-17-2007, 11:10 PM
  5. Full throttle miss b71 50hp Evinrude
    By Kent Bloomquist in forum Johnson Evinrude Outboard Archive
    Last Post: 05-30-2003, 12:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
