I took my 1988 bayliner capri out for the first time last week , it's equipped with a inboard omc cobra 3.0 liter , I noticed water leaking from a freeze plug , in which kept filling the bottom of boat with water so I was running my bilge pump often . Question : is the motor damaged ? Or where do I get a freeze plug to replace it and how to do it myself ? I did have the motor hooked to a diagnostic computer last fall and the shop said I needed a head gasket job but wasn't critical , #1 cyl has 120 psi # 2 cyl has 90 psi # 3 cyl has 90 psi # 4 has 120 which they told me that only gives me the rough idle I've been experiencing . The boat was give to me from a family member and he did not winterized the boat . So I'm concerned about the water leaking from this plug , should I replace all plugs and spark plugs ? Not sure what to do , just gets expensive hauling back and forth to the boat shop , thanks for anyone's help
