I bought a BF 150 with 140 hours on it,supposedly a 2008. Ive finally gotten around to hanging it and beginning the rewireing process on the boat. The harness wires have some green corrosion on some of the pins,so I went ahead and ordered a new harness. I have a shop manual but it dosent say which battery wire is positive and which is negative(stupid question). I assume the wire with 2 wires crimped together is the positive?? The other wire is a single wire. I decided before connecting anything Id check the fuses and the #3 fuse was no good as was the main 90amp fuse(area inside the cover war somewhat corroded and the bolt on the top right was rusty?). Ive replaced them both.So I wanted to confirm the battery cable polarity before connecting the battery.
thanks,
Jerry
thanks,
Jerry
