We have a 2007 Merc 9.9 we use as a trolling motor on a 23-foot Penn Yan. We were trolling about 2.2 mph this past weekend when the motor stopped like it had run of gas. The gas tank was/is nearly 3/4 full but the tank pressure relief valve was tightly closed. After some trouble shooting, we found the fuel line was empty. We tested the hose to find bulb pump were full and under pressure. We connected the line to connector (Part no> 157871a) on the motor casing but could not get gasoline through the connector. Hence, there was not fuel in the filter. The connector looks pretty straight forward. What is inside the connector which could prevent fuel flow? Any and all suggestions greatly appreciated.
