sushi king
When installing the impeller do you have the vains rotating counterclock wise inside the cup?
Both racerone and jgmo are right on with the direction of the pump. Clockwise.
Do not be confused by the arrow on the flywheel, which indicates that the flywheel rotates counterclockwise. There is another gear set below the powerhead, that changes the direction of the rotation so that the pump rotates clockwise as you are looking down at it.
Mike
The engine has only had 3 periods, the last one in salt-water and the push seems to be operating excellent.It seems to me that I should simply unbolt the reduced device, which should then give me accessibility the waterpump.
