Results 1 to 6 of 6
  1. #1
    Angry 1967 starcraft islander
    I have a 1967 starcraft islander with a 120 mercruiser. I have a problem with the lower unit locking down in place, in reverse the prop comes out of the water. When we adjusted the linkage we got it to lock in place but we lost the forward shift all together.Is there anybody out there that has worked on these old boats
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,370
    Default Re: 1967 starcraft islander
    Ayuh,.... My 1st guess is yer lower shift cable is worn/ stretched out,...
    Replacin' it, will probably fix yer reverse lock problem,...
    The actual lockin' is done by the valve on the transom,...
  3. #3
    The lower shift cable is out in the open but where does it go into the back? I have a decent book on it but it don't go into detail very well on that sort of stuff.
  4. #4
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    3,931
  5. #5
    I went out and looked at the lower shift cable. Can that be changed with the sterndrive on or do you have to pull it?
  6. #6
    Join Date
    Dec 2006
    Location
    Posts
    5,370
    Quote Originally Posted by butler View Post
    Ayuh,.... The drive is pulled, 'n the gimbel housin'/ bell housin' needs to be pulled off, or to the side...
    It's all in the manual BD posted the link too....
Similar Threads
  1. Replies: 9
    Last Post: 07-27-2012, 02:16 PM
  2. 1996 baja islander stearing issue
    By baja1996 in forum Boat Steering and Engine Controls
    Last Post: 05-07-2012, 05:20 PM
  3. 1996 baja islander 19 stearing is HARD!!
    Last Post: 05-07-2012, 03:44 PM
  4. my 1901 islander need to try it out
    By Finnish Genius in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-20-2010, 12:20 AM
  5. 1976 starcraft islander stern drive
    By frank_gp_50 in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-02-2006, 04:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
