escape fisherman
I spent the winter rebuilding my BF 225 outboard had 3 cracked pistons all on the port side of motor. Replaced 3 pistons all 6 cylinders were honed and all new rings had the heads rebuilt which had 3 bent valves . from the damage I believe the motor went out of time which cause severe detentation. Replaced all belts (fun getting the cams in time but I got it) Last weekend was the first time getting the boat out took it easy first 45 minutes (below 2000rpms)Ran fine until on the way back after about 2 hours then the motor began to surge between 3200 and 3400 rpms. Then a loud popping or maybe even a banging sound every 40 to 60 seconds slowed down to 2000 rpms with no alarms sounding made it back home but now I'm at a loss ! Just thinking of doing another compression check to make sure no valves hit the pistons and thinking maybe the fuel lost its octane from sitting al winter but it was treated with startron as is all my fuel. ANY THOUGHTS WOULD BE GREATLY APPRECIATED THANKS , Rob.
