Thank you for all your answers. I have good a good ground to the tach, the +12 vdc is good. I have moved the 8 cyl switch to all positions and it is correctly set on the 8 cyl position. I hooked up a jumper wire to the negative side of the coil with the existing connection in place. I started the engine and had no response on the tach. I then tried using the jumper wire without the original wire connected and the engine would not start an a screeching noise came from the coil. It would not stop with the key in the off position. Only when I disconnected the battery did the sound stop. I removed the jumper. Replaced the original connection to the negative side of the coil. I attempted to restart the engine and it would not start. The same screeching sound is coming from the coil. Any ideas? I had a strong running boat with a broken tach and now I have a boat that wont run.
Are 100% sure the coil / ignition is connected exactly as it should be? If all connections are indeed correct, something surely doesn't make sense.
On Tach:
+12 VDC supply to the "IGN" term of tach
Ground to "NEG" or "GND" term of tach
Coil sensor wire to "SEN" term of tach.
On coil:
+12 VDC to the + terminal (if there is a resistor wire in there, is the +12 VDC start bypass energized all the time or only during start?)
Points / ignition module on - (neg) side of coil (Tach wire should be disconnected while troubleshooting to eliminate it from problem)
There are only so many things that can cause symptoms like you describe.
1. Incorrect wiring
2. Shorted points in std ignition system
3. Shorted condenser in std ignition system
4. Bad electronic ignition module, if equipped.
5. Bad coil.
Sounds like there is a dead short from the neg side of the coil to ground, the coil is shorted internally or the +12 VDC start bypass is energized all the time, not during just the start cycle (screaching noise w/ ignition off makes one think this).
Disconnect the neg side of the coil and see it it "screaches" again. If it makes noise, coil is deffinately kaput. If not, then you need to be troubleshooting the neg side of the circuit. Try disconnecting everything (including the output from the alternator) and start from scratch again, starting from the basics, checking voltages and ground connections as you go.
Try seeing what the resistance is in the tach between the "sen" teminal and ground.
Does that system have have the shifter / ignition interupter circuit in it? If so, it may be out of wack in that circuit.
You said it was a TB1, is that a Thunderbolt 1 electronic ignition? Don't think Merc used electronic systems before the early 80's (like '84).
