wishniwasfishin
Bought a older honda motor from a guy its a bf 100 serial number is 1202272, be nice to no the year but i do not. This motor looks like mint condition but wasnt properly put away to rest for a few yrs. I am having a hard time getting this motor to idle, runs the best at higher rpms but however not perfect, sometimes it will run for 5 mins at a high rpm when i turn idle screw in a ways and some times it will only run for a min then die like u shut the gas off. it however wll not idle correctly on its own, just wants to die, if u keep choke half way out it idles the lowest and will stay running if u kinda help it with throttle every 10 to 15 secs.
Things i have done to this motor are
bran new fuel pump (complete assembly)
bran new fuel linesand inlne fuel filter between pump and carb
all parts inside carb are new...also new gasket between carb and intake
new primer ball ,hose ,tank, connectors
all new vacuum hoses
carburator soaked in seafoam for two days( was gummy inside when first took it apart)
i tried for about 3 hrs and cannot get this motor to idle properly
starts usually one or two pulls with choke on
doesnt seem to change how it runs from temp of motor
tried gravity feeding the gas into carb and still ran the same
ive taken carb apart a half dozen times cleanin it blowin out ports and what not
i did notice however when replaceing the larger vacuum lines that ther was alot off chunks of rubber inside them from th hose being so bad.(wondern if it sucked a piece inside the motor somehow maybe?) the lines where in bad shape like i said so i replaced them. This motor just looks like new doesnt look like it has aton of hrs at all just will not idle! also water is comming outa the pisser very nicely. Iv'e trie turnin the air fuel screw in and out in every spot lol, read that it should be bottomed out then uscrew 2 1/4 turns approx. when i cleaned carbs all 4 times i ran a thi piece if speaker wire threw all the little tiny holes on the car, ever singl on, it just acts like a vacuum leak i checked all connections and all areas with a can of wd-40 and cannot ind ay kind of vacm leak. i also took apart the breather valve assembly for the vacuum, cleaned it out. ther wer a few chunks off rubber hose in ther. i even blew just by mouth not air compressor into all vacuum line to make sure somethin wasnt plugged up (air went thew all spots just fine.
someone plz help if they would have any kinda idea.....thank u vey much
