bradtanner
I have a 2003 115 hp carb 2 stroke, it seems to want to bog down and die if given to much throttle to fast....can anybody help?
Normally cause by one of three things......
1 - Fouled carburetors: Clean and rebuild them
2 - Timer base sticking under the flywheel: The throttle butterflies opening up too soon in relation to the timing. Just make sure it isn't sticking as you advance the throttle.
3 - Throttle butterflies opening too soon: They should just start to open when the scribe mark on the metal cam aligns dead center with the throttle cam roller, not before or after.
It's usually fouled carburetors!
