Results 1 to 2 of 2
Thread: 5.9 no crank
  1. #1
    Default 5.9 no crank
    No crank on starboard engine glow plug circuit boat was sunk in the fall so maybe the glow plug relay/module is defective? Where is it located? Thks roger
  2. #2
    Default Re: 5.9 no crank
    Found the problem,the three relays mounted above starter were defective under water,works ok now by replacing relays,roger
Similar Threads
  1. how to crank without key
    By Christina Walker in forum Johnson Evinrude Outboard Forum
    Last Post: 05-21-2015, 08:34 PM
  2. Crank
    By rob_boyd in forum Johnson Evinrude Outboard Archive
    Last Post: 12-04-2008, 03:59 PM
  3. 30 153 4 cyl new crank
    By rehays in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-30-2008, 08:25 PM
  4. Will not crank
    By jchris1062 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-10-2006, 09:45 PM
  5. Replies: 2
    Last Post: 04-29-2002, 04:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
