Hi all. I started my recently purchased 83 Celebrity with 470 Mercruiser for the first time tonight. I only ran it a few seconds with muffs a couple times and shut it off. I went into town to rent a compression tester because one of the plugs came out clean when changing them, like there was a coolant leak into that cylinder. Before starting with comp test, I added anti-freeze to the tank on top since it was empty. After filling it, it looked dirty brown, and when I stuck my finger in it, it was oily. Also, there is no oil on the dipstick, although it was clean and on the full mark last fall. I do not want to start the comp test with oil in the coolant. Should I drain it and re-fill? What kind of oil should I put in this engine? Can I use 5W30? Dave
