Results 1 to 3 of 3
  1. #1
    Default Where are the timing Marks on Marine Power 5.7
    I have a new marine power 5.7 carburated engine. Manual says to check timing at 8 deg at idle. I do not see any timing marks on the engine. I see the line on the harmonic balancer but I do not see a plate with numbers as the drawing in the book shows.
    Anyone know what I might be missing?
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,703
    Default Re: Where are the timing Marks on Marine Power 5.7
    Could this be intended for flywheel timing?
    Look at the rear of the engine and at the flywheel cover.
    You may have an open port (w/ a timing tab) that leads into the outer area of the flywheel, in which case the flywheel may be marked off for ignition timing.
    If not.... then you'll need an add-on timing tab at the timing chain cover.
    The problem is....... you may also want to perform a PPS (positive piston stop) to verify your new TDC markings.
    BTW, look up your Total Advance specs. After you set BASE advance, do a dynamic test/check at 3.2k rpm or so.
    This is to verify your progressive and total advance.
    IMO, setting BASE only, and then walking away is not wise.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,100
    you need a timing tab...I'd call the distributor you obtained the engine from and tell them you want it installed, properly, to maintain your warranty...
Similar Threads
  1. Timing Cover Missing Timing Marks
    By troym in forum Mercruiser Sterndrive Forum
    Last Post: 10-21-2010, 12:59 PM
  2. Eratic timing marks at idle with timing light. 1989 2.3 L
    By NewBoatGuyGeorge in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-23-2010, 11:39 AM
  3. Timing a Marine Power 454 with Delco EST Distributor
    By joekerins in forum Miscellaneous marine engine topics
    Last Post: 11-24-2007, 08:00 PM
  4. Timing problem on 57 Marine Power
    By Fred Keech in forum Marine Power Engine Forum
    Last Post: 12-20-2005, 05:10 PM
  5. Timing Marine Power IO
    By Fred Keech in forum Archive 2003-2009
    Last Post: 08-31-2003, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
