Click for Volvo Penta manuals!
Results 1 to 5 of 5
Thread: Kamd 42a
  1. #1
    Default Kamd 42a
    Hi Guys, I have a Rodman with twin KAMD 42A, the Glow plug light comes on when running, does not seem to have any effect on the running but would like to know why and also how to repair ? any ideas please.
  2. #2
    Join Date
    Mar 2009
    Location
    Brusly, LA
    Posts
    171
    Default Re: Kamd 42a
    Check the relay for the glow plugs, or a short in the glow plug wire. Also determine if the glow plugs are getting power when the light is on, or just the light.
  3. #3
    Thanks for your help, just waiting to get hold of a manual now
    Quote Originally Posted by glen_adolph View Post
  4. #4
    Join Date
    Jun 2009
    Location
    Akersberga Sweden
    Posts
    33
    As the glow plugs on this engines are not standard equipement, are you sure you have glow plugs mounted?, can it be that some previous owner has used this warning lamp for something else?
  5. #5
    Join Date
    Oct 2012
    Location
    sacramento, ca.
    Posts
    306
    you are risking damage to the engine with power continously applied to the glow plugs. yes it will run ok.....but.....glow plugs do not tolerate continous voltage. what happens.....the tips will swell and can seperate and damage a piston top, or, they can swell to the point they stop operating and they cannot be removed because the tip is larger than the glow plug hole. you can still forcefully remove the glowplug, but the tip will remain....then you have to remove the head. if you must, start the motor, then kill the power to the glow plug relay while running.
    *** In comparing the virtues of various calibers, using hollow point ammo: it is absolutely undeniable that, while a 9 mm or .40 S&W may or may not expand, a .45 will never shrink. ***
Similar Threads
  1. Volvo KAMD 44 EDC
    By rainerg2 in forum Volvo Penta Diesel
    Last Post: 05-19-2013, 07:35 PM
  2. KAMD 300 EDC experiences
    By hgput17 in forum Volvo Penta Diesel
    Last Post: 08-15-2012, 05:41 AM
  3. Volvo Kamd 44p Overboost
    By Steve Harrison in forum Volvo Penta Diesel
    Last Post: 06-11-2012, 08:19 PM
  4. Kamd 300 compressor
    By permit4u in forum Volvo Penta Diesel
    Last Post: 12-21-2008, 02:12 PM
  5. KAMD 300 problem
    By haasmd in forum Volvo Penta Diesel
    Last Post: 11-28-2008, 07:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
