1998 40HP Mercury Constant Beep... More annoying then the wife!
jeffhall
Hi Guys,
Cold start 1998 40HP Mercury full of OIL and as mentioned cold just beeps constantly its not a beep beep but a beeeeeeeeeeeepppppppppppppppppppppp that never ends.
I have tried disconnecting the temp sensor wire and that did nothing.
The motor starts and runs fine though I didn't push it for obvious reasons.
Just wondering if anyone can shed some light ?
Jeff
NOTHING is more irritating than... Never mind.
I suggest you run 50:1 premix until you get it straightened out. (That way you can't hurt anytning.) It's probably adud sensor.
Jeff
Jeff
Thanks mate I am not using it now anyway no one can handle that thing beeping whilst going down the lake !!.
I have read that it can be dud alarm module in the front controller, looks a lot like this as it beeps from cold start and a constant beep is apparently temp sensor where as a beep beep beep beep is no oil.
do you know anything about those beep codes?
Thanks Jeff
The buzzer is supposed to do a " self check " beep when key is turned on.---If the buzzer has it's own circuitry then perhaps it is just a defective buzzer.---If not then maybe the module is bad.
Sorry for my ignorance but
What do you mean by buzzer has its own circuitry ? The Module located in the front control or at the engine ?
