OwnAMoneyPit
Good evening all!
Am hoping someone might be able to point me in the direction of a fix before my boat becomes a permanent fixture at the bottom of some lake.
The Setup: 1992 Bayliner 2050 with a Mercruiser 4.3L Gen II Alpha One, Thunderbolt IV ignition, carbureted (2BBL). Motor serial number is D701474. Compression tests from late last year (when it was still running) were good although I can't find the exact numbers.
The Problem: Over the winter I replaced the wiring harness, ignition coil and ICM trying to address an intermittent surge/backfire/cut out situation that has plagued me since I picked this thing up a few years ago (plus the existing components were third hand when I got the thing and were pretty tired...). When I went to de-winterize and test fire a couple of weeks back the engine cranked fine but wouldn't fire.
What I have tried: I verified fuel getting to the carb so am thinking no spark. Went back through all my connections (just to make sure I didn't miss something easy) and found what I think could be problem straight off. With key in the Run position I am getting +/- 11.85V at both the positive and negative terminal of the ignition coil which seems odd. Following the power to the ICM i read 11.85V heading in on the purple lead but get almost nothing coming out of the red/white back to the ignition sensor. Following the troubleshooting guide it would seem to indicate a bad ICM (which would suck as this is a brand new unit!) but when I tested again with the original ICM (which was working before the harness swap) I get the same exact condition. I also tested with the original ignition coil (same results) and tested with the tach lead off (same results). SO either both ICM's are toasted in the exact same way OR (fingers crossed) I have a problem somewhere before the ignition coil that is causing it to ground itself. In addition I have ensured that the shift cutout switch is NOT engaged.
Am wondering if anyone else has run into this issue and could possibly point me towards whatever solution they found. Haven't been able to find anything in any forums re: the positive voltage at the negative terminal and am really hoping that has something to do with it. Am really hoping to avoid putting this thing back in the shop and paying my mechanic to go fishing for the issue, so any guidance is appreciated!
