MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 6 of 6
Thread: 40hp mercury
  1. #1
    Default 40hp mercury
    Installed new water pump now water coming out of spark plugs. Any idea why?
  2. #2
    Default Re: 40hp mercury
    Quote Originally Posted by kimcrwbr1 View Post
    Probably just a water jacket cover gasket. Mercs dont have a head just take the cover off and get a new gasket clean all the surfaces good and use a light coat of aviation permatex on both sides of the gasket. Thats the brown stuff you brush on get the bolts good and snug and let it sit overnight then you should be set to go.
    http://www.ebay.com/itm/Mercury-40-H...4ec70d&vxp=mtr
    Depending on your HP and serial number it should look similar to this it`s just leaking out the water jacket cover around the spark plugs. Real common. Be real careful loosening the bolts heating it up around the bolts prior to loosening helps. The bolts tend to break real easy the older the motor. Take your time!
    took water jacket plate off have a small hole in cylinder wall above top spark plug looks to be old but not sure if the motor is toast looks small enough to patch and what should be used
  3. #3
    ???... Unusual. Do you know the history of this motor? Pics would be very helpful.
  4. #4
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    14,541
    Seen that many times, caused be overheating due to a bad impeller.
    The cover has to come off. The bolts will most likely snap off if you simply unscrew them, so you'll need an acetyylene torch to heat the nuts red hot BEFORE trying to remove them. With the cover off, you should flat plate sand it flat, then install a new gasket with lots of silicone. And use all new grade 8 bolts!
    Jeff
  5. #5
    Jeff, he says the water cover is off. What about the hole?
  6. #6
    Would still like to see the hole. Why and how did it get there?
Similar Threads
  1. 2001 mercury 40hp low rpm
    By sparky1988 in forum Mercury Mariner Outboard Forum
    Last Post: 03-28-2013, 05:40 PM
  2. mercury 40hp 1980
    By Becky Watkins in forum Mercury Mariner Outboard Forum
    Last Post: 07-28-2012, 12:13 PM
  3. Replies: 3
    Last Post: 03-24-2012, 07:14 PM
  4. Problems with my 40HP Mercury
    By Marc Brown in forum Mercury Mariner Outboard Archive
    Last Post: 03-07-2006, 04:22 PM
  5. 1979 Mercury 40hp
    By ken in forum Outboard motors archive 2000-2004
    Last Post: 08-18-2002, 10:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
